4wd
Old Jan 16, 2023 | 06:29 PM
corsav12's Avatar
corsav12
Default 4wd
4WD I'm new to this I have a 95 Dodge Diesel 4 WD I have never had a 4WD truck and not sure how to put it IN 4WD I know you put it in neutral I tried to put it in 4WD but the shifter won't go into 4 WD not sure if I'm doing something wrong
Old Jan 16, 2023 | 08:23 PM
Truck in gear, moving slowly, NOT accelerating, give the stick a shove, and it should go right into 4wd. The system is designed to allow shift to 4 hi at speeds up to 55 mph. But, if you are trying to accelerate at the same time, it simply is NOT going to go. Pressure on the gears will prevent it.
Old Jan 16, 2023 | 08:27 PM
corsav12's Avatar
corsav12
I was stopped I put it in neutral and then tried to put it in 2 if I put it in 4wd do I put the truck back in drive or leave it in neutral
Old Jan 16, 2023 | 08:34 PM
IN GEAR. Drive, 1 or 2. Moving slowly, foot off the gas. Or, take it out on a DIRT road, run it up to 40 or so, let your foot off the gas, and shift. Into our out of, doesn't matter. For 4 lo, speed LESS THAN 5 mph, and a quick HARD jerk on the stick. And even then, it probably will grind..... So folks stop, trans in neutral, and shut the engine OFF to shift into 4 Lo. (trans in neutral)
Do NOT use any variety of 4wd on a high traction surface. Things will break.
Old Jan 16, 2023 | 10:02 PM
Keith_L's Avatar
Keith_L
There's a synchro in the t-case that should allow shifting into 4wd at most any speed but they frequently fail. Still, you really should be able to pull it into 4hi while stopped or possibly rolling slowly as HeyYou suggests
How many miles on truck?
Old Jan 16, 2023 | 11:07 PM
corsav12's Avatar
corsav12
263,000 miles
Old Jan 16, 2023 | 11:09 PM
corsav12's Avatar
corsav12
I have a dumb question do I keep it in drive then put it in 4wd
Old Jan 17, 2023 | 12:25 AM
HeikIlm's Avatar
HeikIlm
Post #2, HeyYou explained it already.
Old Jan 17, 2023 | 06:29 AM
Moparite's Avatar
Moparite
If you have an owners manual it's all in there, I believe it tells you on top of the drivers visor also.
Old Jan 17, 2023 | 09:33 AM
Keith_L's Avatar
Keith_L
Yes, you can be in D.
The early NP241s had a host of minor issues. At 263k behind a diesel the single row input bearing may have munched itself (which probably shouldn't preclude 4wd engagement) or the shift forks could be worn/gone.
Without being there, it's hard to know. The earlier 'cases also used a different shift pattern which requires more force to engage and is less positive when it does.
