Old 08-06-2015, 12:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Low Beams not working
Old 10-22-2013, 11:17 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,208 Likes on 2,959 Posts
Originally Posted by rafael505
yes, yes, lol, i have searched everywhere seeing if otheres have had the same prob as me, That is exactly my problem too, please let me know hows its going on fixing the prob, right now my lights don't turn on even when i tilt the wheel up or down im not good at stuff like this but Ill get in there and give it a try hehe
Check and make sure the bulbs are good first, then have a look at the headlight switch.
  #22
Old 05-25-2014, 02:12 PM
iampocket's Avatar
iampocket
iampocket is offline
I have a similar problem on my 2001 1500. Low beams don't work, but high beams do. I checked to make sure the connections were good on both the master control switch (on the steering column) and the headlight switch itself. It seems all the connections are fine. Was thinking about putting in new headlight switch to see if that fixes the problem, but I was wondering if there is a way to check to see if the switch is bad. I don't want to buy a new switch and replace just to find out that's not the problem. Any help would be greatly appreaciated. Thanks
The following users liked this post:
mello (12-01-2021)
  #23
Old 05-25-2014, 03:14 PM
HeyYou is offline
See where you run out of power at. This assumes that the bulbs are good.
  #24
Old 10-11-2015, 07:52 PM
Dawnygirl's Avatar
Dawnygirl
Dawnygirl is offline
Default turn signal causing low headlight to not work.
Hello, my name is Dawn and I own a 2001 dodge ram sport. I am having the same problem but I took my steering column apart and the connection to the turn signal is burnt up, I can find the turn signal but the main plug in to wiring harness I can't find, the only way I say to wiring harness is because I took pictures and that's what the autoparts stores keep saying. Is there a easy way to fix besides buying a wiring harness?
  #25
Old 10-12-2015, 09:50 AM
HeyYou is offline
Might be able to get the connector from the dealer, or, they should at least be able to point you at somewhere to get one... Other alternative would be to cut one out of a donor truck in a junk yard somewhere....
  #26
Old 02-05-2018, 03:30 PM
Justin rowley's Avatar
Justin rowley
Justin rowley is offline
Default 97 ram 1500
I had very similar problems with my 97 dodge ram 1500 I replaced the head ight switch last year one of the contacts on the harness had melted and this year it seems to happen again but it was the connection at the splice that melted so I just reconnected The Wire I guess every year that wire will get shorter unless it melts the harness again glad I bought the lifetime warranty for the switch
  #27
Old 02-05-2018, 04:43 PM
HeyYou is offline
Get the heavy duty headlight harness from LMC truck. It's plug and play, and uses relay to power the headlights, instead of the switch. Much better.
  #28
Old 06-06-2019, 07:17 PM
Rinn's Avatar
Rinn
Rinn is offline
Thank you for leaving these threads posted. I had the same problem on my 97. Found the blue wire with the white stripe had pulled out of the harness at the multi switch. The previous owner had tried to fix it by shoving the end of a zip tie in the coupler to hold the wire. Im going to the junkyard to hopefully find a good coupler since the lock tab for that wire is broken. Just want to take the opportunity to thank everyone on here for the hours of head scratching and the money you save me with all the help you give on here. Thanks again
  #29
Old 06-06-2019, 07:23 PM
HeyYou is offline
We aim to please. Glad we were able to help ya out.
  #30
Old 11-21-2019, 04:22 PM
Steve Sutton's Avatar
Steve Sutton
Steve Sutton is offline
Default No low beam on one side on 02 ram 1500
Originally Posted by rocoforce
Hi, I'm new to this site and hope someone can guide me to the right area or is able to help fix my problem. I have a 2001 Ram 2500 5.9L Diesel and it's been a champ up until this fall when I crossed the 100,000 mile marker. At first, my low beam headlights seemed to quit working, then they would be OK.
When they would not work, I could switch over to the high beams and then back, usually it would fix the problem. I looked at a wiring diagram for the multifunction switch and figured it must just be a bad switch. Got a new multifunction switch from AutoZone ($59) and installed it with no problems. The lowbeams seemed to work normal again, but for just a day. Has anyone else had this issue and what was the fix? I've seen where someone said it was a loose cable, but which one? It appears that the controls to the headlights are all "Ground" related. Is it possible to hardwire a new ground with a relay and have the lowbeams on all the time, even when the highbeams are triggered? Thanks, looking forward to many great responses.
I read a and I tried it,seems stupid! Took the fcmoff of the side of fuse block and bent the tabs down toward the fuse block.... bolted it down and lights work.so I'm thinking of that is a bad design and going in too far and shorting out!
Quick Reply: Low Beams not working
