Ram turns over but wont start
Old 02-20-2010, 08:32 PM
kfdcowboy's Avatar
kfdcowboy
kfdcowboy is offline
Default Ram turns over but wont start
I have a 1999 Dodge Ram 1500 with the 5.9L and it will crank and crank but to no avail. had battery tested, it was fine. new plugs and wires, new dist. cap and rotor, new ignition coil too. No wires crossed either. Fuel pump is running fine, kicks right on when key is turned, lots of fuel pressure in the rails, tested and running within normal limits. Tested all injectors, all came back with proper resistance. after cranking i can pull a plug and smell gas on the end. Pulled plug and stuck back in wire, tried cranking it and all i get is a weak orange spark every 2 or 3 seconds.
any help out there? I'm out of ideas.
Thanks in advance
Old 02-21-2010, 07:22 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Did this just happen one day? Or did it get worse and worse in time?
Old 02-21-2010, 09:54 AM
Hammer Down's Avatar
Hammer Down
Hammer Down is offline
My guess is either your coil is bad or you crank position sensor is bad. Either of these can prevent ignition.
Old 02-21-2010, 09:56 AM
zman17's Avatar
zman17
zman17 is offline
Not saying it can't be defective, but, the OP said the coil is new.
Old 02-21-2010, 09:58 AM
Hammer Down
Missed that part. Sorry.
Old 02-21-2010, 11:47 AM
kfdcowboy's Avatar
kfdcowboy
it started friday night, truck had been running rough, pulled the cat and replaced it with a new one two weeks ago, ran fine for a while, then friday was pulling into driveway and it just quit, put it into neutral and it wouldnt start again, pushed it into barn and it hasn't started since.
Old 02-21-2010, 12:56 PM
J415's Avatar
J415
J415 is offline
When you turn the key, do you hear the fuel pump whine? Fuel pump could be busted. Just a thought since you seem to have done everything else.
Old 02-21-2010, 01:00 PM
kfdcowboy's Avatar
kfdcowboy
fuel pump is new a month ago, kicks on just fine, good pressure in the rails.
Old 02-21-2010, 01:36 PM
J415's Avatar
J415
J415 is offline
Check your fuses and your relays. Could also be you ignition coil pigtail. Mine got a short in it and it would cut out once and a while. Other times it just wouldn't start. Test your ignition coil to be sure. I had an MSD replacement coil and it died 3 months after I got it.
Old 02-21-2010, 10:25 PM
kfdcowboy's Avatar
kfdcowboy
checked all fuses and relays, everything checked out. put new crank sensor in. put new pick-up coil/stator in. all to no avail. everything is NEW. checked all my grounds. checked resistance and supply voltage to everything. it all checks out. why the heck wont it start? new coolant temp sensor too since that was going bad. ANYONE?!
Quick Reply: Ram turns over but wont start
