Do downstream o2 sensors effect gas milage?
For 1994-1999 Ram 1500s, the O2 sensor going into the cat is the "upstream" or "pre-cat" sensor. As HeyYou stated, it has a profound effect on gas mileage. It "judges" the exhaust gasses, and tells the PCM whether its running lean or rich, and the PCM (with input from other sensors) adjusts the air/fuel mixture appropriately.
Can you disconnect the upstream sensor to see if mileage improves? Here in AZ my truck is subject to emissions testing so removing isn't an option.
I've done the kegger / throttle body mod, plenum repair, complete tune up, CAI, cat back exhaust, e-fan conversion, water pump, thermostat, timing set and still only got 10 mpg. ?!?!?!?
I'm hoping its the sensor. I realize mpg and 5.9 don't really go together but have read where some guys are getting mid teens. I was hoping 13 mpg to be realistic.
