97 Ram No Check Engine light and wont start
Old 04-05-2011, 08:17 PM
97RAMMAN's Avatar
97RAMMAN
97RAMMAN is offline
Default 97 Ram No Check Engine light and wont start
I have a 97 ram 1500 2wd with the 318. It was running fine then just shut off, it now turns over but won't start. The check engine light doesnt come on with the key in the on position now. It blew the fusible link for the fuel pump in dtc and I replaced that but now still won't start. Any help ya'll could give would be greatly appreciated.
Old 04-06-2011, 08:08 AM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old 04-06-2011, 08:17 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Got spark? Getting fuel(check with pressure gauge)? Try swapping ASD relay with the horn relay or similar. How was it running prior to this incident? Try this and see if any codes come up https://dodgeforum.com/forum/2nd-gen...code-list.html
Old 04-06-2011, 02:36 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Welcome to the site
Do you have any idea why it blew the link? Maybe other electrical damage occurred also
Old 04-07-2011, 11:06 AM
97RAMMAN's Avatar
97RAMMAN
97RAMMAN is offline
no spark or fuel it was running fine and died i replaced the fusible link and the check engine quit coming on when i the key is turned to the on position. al other lights come on oil pressure, brake ect... and the green light on the cruise contol stays on, think i may of fried computer ????? Tried the key play but no check engine light at all and mine doesn't have the digital speedo.
Old 04-07-2011, 11:09 AM
zman17's Avatar
zman17
zman17 is offline
Did you check for codes?
Old 04-07-2011, 11:16 AM
97RAMMAN's Avatar
97RAMMAN
97RAMMAN is offline
Don't have an obd here, can a guy rent one from the part stores?
Old 04-07-2011, 11:23 AM
zman17's Avatar
zman17
zman17 is offline
Did you look at the link I provided in a previous post?
Old 04-07-2011, 12:14 PM
97RAMMAN's Avatar
97RAMMAN
97RAMMAN is offline
Yea and it didnt show anything??
Old 04-07-2011, 12:15 PM
97RAMMAN's Avatar
97RAMMAN
97RAMMAN is offline
Yea and it doesn't show anything???
Quick Reply: 97 Ram No Check Engine light and wont start
