just move the iat sensor! for permanent cold air!
cold air intake or the hot air intakes.. doesnt matter just move ut iat sensor into the air intake system and plug it back in.. will always read ur getting cold air. mine reads 80-100 degrees all the time.. before it was reading 120-160 all the time i live in florida so its always hot. i got my intake off somone and he included the new iat sensor.. so i still have my old one in the engine and i can choose weather iw ant good gas millage ill plug it back into motor and if i want more power i plug it into the intake!
Uh, what drewactual said.
The net effect of the IAT relocation is a richer mixture during open loop modes. If you've got some mild WOT pinging it might alleviate it, but it might also come at the cost of greater combustion chamber carbon deposition during warm-up.
Myself, I'm keeping the IAT downstream of the throttle body even if I should some day decide to install the FI Airgap. I'd rather go further than faster.
Trending Topics
I did some reading on the IAT a little while back.. It's funny, because it is really hard to find out precisely what it does and when it does it.. it does have bearing on a/f, but it's difficult to determine how much..
let's say it does dump fuel because it thinks the air is cooler (or maybe even because the air is cooler).. what good does that do you? A richer engine doesn't produce as much gitty-up as a lean engine.. it's only dumping fuel because cooler/denser air is tougher to ignite than warmer/less dense air...
One thing for certain the IAT WILL do if it isn't reading somewhat correctly: it will throw at you a p1281.. Engine too cool for too long.. And you will chase your tail trying to figure out what is wrong with your cooling system until you stumble across that, and most likely by accident..
and another thing about the IAT that surprised me: they may or may not be sending good information as it is.. the parameters they work in are pretty broad is my guess.. if you unhook it you should get an instant code- but that doesn't mean the sensor is in optimum condition, it just means the PCM knows it's plugged in..
as far as having it moved from the manifold- I have mine in the air-hat because of the FI.. I don't think it's harming a thing there- and because the o2's have the final say in a/f ratio.. but that doesn't mean the PCM is tickled about conflicting information either.
