Transmission VIN Challenge
I was never able to find anything like that..... The dealer might understand those numbers, but, it seems no one else does. There are some 'explanations' of what the numbers mean in various places, but, there doesn't seem to be any consistency on how the numbers are stamped on the trans.... the formats don't always match up to what you would expect.
Difference between 2 and 4 wheel drive will be obvious though..... just look at the tailshaft housing. If it looks like the drive shaft plugs directly into the trans, that's 2wd. If the opening is 6-8"s, 4wd.
To tell the difference between RH, and RE's, look at the connector on the drivers side of the trans, about 2/3rds of the way back, an inch or three above the pan rail. 3 pin, is RH, 8 pin is RE.
There are some various pinout differences over the years on the RE models, but, swap the appropriate year electronics into it, and it will work for your truck.
Lets break this down. First this is not a VIN (Vehicle Identification Number). It is actually a part number with build date. PK means package. 52118426 is the part number for a 46RE transmission out of either a full size van or truck. 2579 is the build date meaning it was build the 257 day and 9th month. It was built September 14, 1996. 7717 is sequence number meaning it was the 7,717 unit built. Was this a test or were you looking for specific info??
decifpher P K #'s
Any body Is there a book, chart or link where I can enter the PK #'s of removed trannys so I can find out the make (2w or 4w drive) and the vehical they came from? where did you get the info from?
Thanks HeyYou; for the info and gdstock for the pics!!!
OP - To make it simple - No. See Post #12. Probably not such a list. If there is, no one here knows where it may be. A 46RE transmission is a 46RE transmission, in only 2 models...2wd and 4wd. The difference is the OD section. The 4wd model is made for transfer case to bolt onto, and the 2wd does not.
Hey guys, Im resurrecting this thread because Im trying to determine the year-built of this transmission I have. I already know its a 46RE. This transmission is in a '99 model Dodge 2500 2WD truck with the 5.9 Magnum engine.
The reason for this post is that upon taking down the trans-pan, the valve body transducer is the black/square type that is typically seen on 2000-and-up 46RE transmission. The '96-thru-'99 transducer is round and has a different connector on it. So Im trying to figure out how it is that this '99 model truck came to have a >=2000 transducer in it.
I sent the VIN to that online Dodge Support site and they replied with the Build Sheet listing and confirmed that truck indeed was built with the 46RE from the factory. But what Im trying to determine now, is if the transmission that is in the truck now was a newer replacement, or is it only a newer valve body.
Thank you for any info you guys can share.
I recently bought this truck and it was throwing the code that said to replace the GovPressSolenoid and Transducer. I think, "no problem" and ordered the kit for this year-model truck.
When the kit showed up in the mail, I took the pan down and behold the transducer is different, so I had to return that and get the square/black, later version of the transducer seen in >+2000 models.
So I put the new solenoid and transducer in, put fluids back in and the truck runs and shifts great. BUT for some reason the TRANS-TEMP light stays on all the time. It comes on immediately upon starting the truck when theres simply no way the fluid is hot yet.
Just to cover my bases, I removed the check-valve in the hydraulic line up near the radiator to rule that issue out about fluid restriction.
After doing some research, I read somewhere that my 1999 ECM might be getting confused because the 2000-model transducer is sending a different reading that the 1999-model transducer usually sends and because of this difference, the ECM is displaying the TRANS-TEMP light.
Right now there are no codes and the trans operates correctly. Just trying to track down why the heck this light is on and will not go away.
