Window off track
Window off track
I have a 97 1500 dodge ram, NOT power windows. The glass first got off course when it froze to weather stripping, it still worked but sometimes got caught on weather stripping for a second before clunking back into postition where it should have been as I have lowered the components in the door. Yesterday it made a funny sound when I was lowering the window and then crashed to the bottom of the door. Thankfully it didn't break but now i don't know how to get it back on track and it seems to be beneath the whole mechanism now.
HELP!
So far I have only taken off the plastic door panel and have fiddled around with the glass but nothing more.
HELP!
Have you taken the door panel off yet to look? Did the bolts that bolt it to the mechanism snap or loosen and fall off? If the nuts just loosened and fell off then reach in there and pull the window up, set the studs back in the track and tighten the nuts up. If the studs on the glass are actually snapped then that sucks.
I had the metal clamp that holds the glass release from the glass and it dropped inside the door.
Here's my DIY notes:
1. Had to remove the inner door panel and lifted the window out of the door.
2. Unbolted the metal clamp from the lift mechanism, cleaned up the gunk on it, cleaned off the window where it attached, smeared some Gorilla Glue on the clamp's inner surface where it contacts the window glass and slid if back onto the glass.
3. I let it set up then reinstalled the window in the track, with the lift about halfway up. Bolted the clamp back onto the lift mechanism and its been good for the last 2 years.
