Wont go over 20 mph
This sounds a lot like a clogged catalytic converter. Unscrew the upstream oxygen sensor to relieve exhaust pressure and take it for a spin. If the symptom is greatly improved, you've got a clogged cat, and almost certainly a blown intake manifold plenum gasket to go with it. There is also a strong possibility of a cracked head, as the overheating of the combustion chambers that accompanies a clogged cat quite often causes the heads to crack.
Also, if it's a clogged cat, you'll want to replace that upstream oxygen sensor along with the cat. The same oil that clogged the cat will foul that sensor.
on
You can take out the pre-cat O2 sensor (physically remove it from the pipe) and see if it runs any better, if so, gut that puppy or take it out, depending on the local laws in your area. Feds says you have to have a cat but I doubt they're gonna check, local emission laws are usually more enforced...
on
Trending Topics
Definitely clogged cat same thing happened to me but I just happened to have one of those fancy exhaust cutters that's a chain hooked up I don't know how to explain it but its a lot easier than a sawzall or grinder might wanna invest in one its really convienient
Here's a video of it in action
https://www.google.com/url?sa=t&sour...KmmCVs3nnq3cCg
