1995 ram 1500 code 32 and 37
Old 10-02-2012, 03:30 PM
charmed's Avatar
charmed
charmed is offline
Default 1995 ram 1500 code 32 and 37
This is my first time asking for help in this section. Thanks for your help. I bought my new bride a 95 4x4 Ram 1500 shortbed RC so her dog does't ride in my truck. It was cheap. (1275.00) I have had other Chry products but this is my first Ram. I have replaced the entire dash assembly and pulled the carpet and seats for cleaning. ( it looked as if they were hauling coal in the cab ). It seems to idle ok but when backing up it has and engine missfire, also happens on moderate accel in forward. It has code 32 and 37 stored. ( I can't seem to find the code list for this year model on this forum, I'm sure its my fault ). The fuel pressure is steady at 40 psi but jumps up and down on the misfire. I had to repair the vac lines on the pass side under hood to make the a/c work but haven't found any vacuum leaks afterward. Any ideas ?
Old 10-02-2012, 03:31 PM
charmed's Avatar
charmed
charmed is offline
sorry, the engine is a 5.2 mpi wnd the truck has 138k. thanks again
Old 10-02-2012, 04:34 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Make sure you read note #1 . A simple reset of the PCM may solve that code. But you have to actually look and see if you have a tranny temp sensor in the line.
Old 10-02-2012, 05:02 PM
charmed's Avatar
charmed
charmed is offline
Thank you . I will check to see if it has a sensor for trans temp. BTW there is no hitch on this truck if that matters and I've the battery disconnected and only driven this truck maybe a block since I bought it 1 month ago.
Old 10-02-2012, 05:04 PM
charmed's Avatar
charmed
charmed is offline
And how the heck do you get to the egr valve ? That darned thing is buried in the back.
Old 10-02-2012, 05:36 PM
zman17's Avatar
zman17
zman17 is offline
Yep, sure is. I suggest you get a Haynes manual AND download the appropriate one from the FAQ/DIY section. Both will help a lot. With this project and ones in the future.
Old 10-02-2012, 05:46 PM
charmed's Avatar
charmed
charmed is offline
Any thoughts to fuel pressure at 40 psi ?
Old 10-02-2012, 05:53 PM
gdstock's Avatar
gdstock
gdstock is offline
You are on the low side. Should be about 49-50.
Old 10-02-2012, 06:09 PM
zman17's Avatar
zman17
zman17 is offline
Sorry but, fuel pressure is lower for a 95. Doesn't really matter anyway. If it doesn't hold the pressure for a reasonable amount of time and has zero pressure in the AM, the regulator is bad(or there is leaking injectors, which can all can be checked with a pressure tester). And if the pickup screen is clogged on the bottom of the pump, the pump needs to come out anyway. And btw, the regulator doubles as a filter too.
Old 10-02-2012, 07:07 PM
gdstock's Avatar
gdstock
gdstock is offline
Ooops....
Quick Reply: 1995 ram 1500 code 32 and 37
