line pressure adjustment 46re
Old 11-30-2012, 12:22 AM
sledpull97's Avatar
sledpull97
sledpull97 is offline
Default line pressure adjustment 46re
I have a 97 ram 4x4 5.9 with a 98 tranny..unknow miles but had been rebuilt at some point :/..anyhow It shifts sloppy from 1-2 but is otherwise great I adjusted the tv cable and man that's a pain I kinda went in blind and moved it back towards the firewall quite a bit and it helped. but the pan leaks and I'm going to weld a bung in for a temp probe and drain plug..I have read about the pressure adjustment. how do I do it? safe amount of turns and the out come? thanks.
Posted from Dodgeforum.com App for Android
Old 11-30-2012, 12:45 AM
Arde's Avatar
Arde
Arde is offline
Adjust your front band. Loosen the locknut on the adjustment screw, torque the adjustment screw to 72 lb/in with a lb/in torque wrench. Back it off 2 7/8 turns and hold it from turning while you tighten the locknut down to 30 ft/lbs. If you can't get a torque wrench on the locknut while holding the adjustment screw, just tighten it down good keeping 30 ft/lbs in mind.
Old 11-30-2012, 12:56 AM
sledpull97's Avatar
sledpull97
ok,any auto parts stores (Napa,AutoZone,O'Reillys,farm and fleet,are my closest) carry a decent cheap wrench?
Old 11-30-2012, 12:11 PM
OK_Ram's Avatar
OK_Ram
OK_Ram is offline
Just rent one from the parts store and when you return it they refund you the money.
Old 11-30-2012, 01:09 PM
sledpull97's Avatar
sledpull97
I called and I can get one for 22 bucks,and what about line pressure? how many turns? or leave it?
Old 12-01-2012, 10:03 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The factory adjustment is in this thread, https://dodgeforum.com/forum/2nd-gen...-in-trans.html
And if you want to fool around with it after its back to stock. http://www.bionicdodge.com/Download/...Adjustment.pdf
Quick Reply: line pressure adjustment 46re
