engine rebuild questions
Old 11-18-2013, 05:59 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
Yes. They get weaker over time. And if everything else is gonna be new, no point screwing it up with old valve springs.
Old 11-18-2013, 06:49 PM
dieselsuburban95's Avatar
dieselsuburban95
dieselsuburban95 is offline
Ok ill add that to my list
Old 11-21-2013, 12:05 PM
dieselsuburban95
Do yall think it could be just the plenum gasket is thee power loss problem it runs good other than power and the slight shake at idle
Old 11-21-2013, 12:52 PM
chromed95's Avatar
chromed95
chromed95 is offline
certainly could be a leading factor, especially if it's never been addressed. Do a compression check like hey you said before and see where you stand there, and that'll give you an idea of what else could be tired. report back with your numbers, wet and dry!
Old 11-21-2013, 12:56 PM
dieselsuburban95
Ok im starting to rethink the whole rebuild thing right now lots of money im now thinking plenum and clean throdle body and see where that goes
Old 11-21-2013, 01:36 PM
Plenum fix, timing chain and gears, (water pump optional, but, it's gotta come off for the chain and gears anyway) full tune up, throttle body clean. Take it from there. Can do all that for under 300, if you don't have to pay someone else to do it.
Old 11-21-2013, 02:11 PM
dieselsuburban95
I can do it all myself thats not a problem I think ill try that first
Old 11-21-2013, 06:53 PM
Spillage's Avatar
Spillage
Spillage is offline
Unless I missed it, I don't think the CAT and O2 sensor have been mentioned yet.
At those miles, it should be on its 3rd CAT by now, and due for another soon... a clogged CAT will surely hamper performance.
Old 11-21-2013, 07:00 PM
dieselsuburban95
No cat its been cleaned by previous owner and has a flow master muffler I dont know about the o2 senser
Old 11-21-2013, 07:01 PM
dieselsuburban95
It runs great just no guts
Quick Reply: engine rebuild questions
