no heat
Couldn't find my angle screwdriver so I had to go buy one, but I got it off and disconnected to actuator. I manually turned the blend door as far as it would go. The heat got a little better but not like it should. I also noticed that it does get warmer when I press on the gas. I guess it could use a good ole drain/flush/fill. I haven't ordered them couplers yet but will soon. We are getting pounded by snow right now so I cant flush it right now because I have no drains in my barn. When I get the chance I'm going to disconnect the heater hoses and back flush it as well.
I have a problem that I loose heat at a traffic light. It returns after I pull away but it is never great guns hot like it used to be. I checked the trap door to the cold air and it is functioning correctly as well as the thermostat. Any advise? Please contact me at donparadowski@yahoo.com
Try burping the cooling system -- a search of this site will turn up the directions. If that doesn't fix it, or doesn't fix it for long, and you aren't losing coolant, replace the heater core. Or just keep burping the thing every so often until you're good and tired of it, then replace the heater core.
What if you don't have that actuator on the bottom of the box? My 98 only throws heat when you set it at max A/C with the heat turned to full hot. Thought about the heatertreater but I cant find the actuator. There's a little silver nub sticking out of the bottom of the box that moves very little with the heat control. Looks like where all the pics say it should be. Really don't want to tear the dash appart if I don't have to.
