Too many issues. PLEASE HELP
Okay guys. Im a new member to the forum. A while back, my truck broke down. Thw overdrive housing broke off and the transfer case dropped. Its 97 dodge ram 1500 with a 5.9 magnum and it has 177 miles. I do not have a code because my spot to plug in my reader is gone.
Problems. My speedometer only works when it wants to. Whenever it does work, it only goes to 70 and wont go over that. The rpms stay steady at 3k. The engine feels bogged down bad, but oil and transmision filter is and fluids all look great. I also feel like my front drive shaft is turning while im driving because i hear a sound like a ujoint under me towards the front. Why would it turn if its in 2wd? I press on the gas heavy and only back wheels spin. Someone please help.
So how did you fix the O/D housing falling off?
177,000 miles? (I only wish my truck had 177 miles on it.....)
What happened to the diag connector? It should still be around somewhere.....
How old is the front O2 sensor? Have you fixed the plenum yet? (have a read thru the plenum thread stickied at the top of this forum.)
Apart from dropping the transfercase, and diag connector not in its usual location, you're describing common issues covered many times over.
Beyond HeyYou's comments, look for threads on the CAD, for the front driveshaft turning... the root of this is typically a vacuum leak.
Also guys, I did find the OBD2 port, but I have a simple code reader. Bo diagnostics. My cats have been gutted, I checked the other day. I got two codes, PO123 and a PO500 code. PO123 is for the throttle body position sensor. And the PO500 is for the VSS. Replaced the VSS on the tranny but apparently that wasn't right. Could the VSS prevent my truck from switching into overdrive? And what about the TPS?
