Cold blooded SOB
#21
#22
#23
So, I finally took the advice I've read on here dozen times or more and unplugged the coolant temp sensor. .. idle at 13 degrees for 20 minutes. Not a chug, burp it hiccup. Drove this morning and no stalling at the stop signs. Other than getting mopar sensor what else should I look at?
Thanks
Thanks
#24
#25
#26
#27
#28
#29
What I thought.
So, lets see if I'm understanding the situation...
With the 'non' Mopar ECTS plugged in, I get hard starts, miss-fires on start, stalling at stops and bucking (if I'm moving) @ about 150f'ish, @ full warm-up things run pretty smoothly.
Only have issues at cold and warming up with the sensor plugged in.
With the ects disconnected I have ZERO issues...except for it's pretty much pouring gallons of gas down the cylinders. (as if it didn't suck fuel unabated before.)
Once I replace with a genuine mopar sensor and my problems come back, I'll need to look at replacing the ECM....as long as there is no issues between the connector and the board.
If the ECM does need to be replaced, it has to be flashed with the correct VIN or I trade one problem for a whole host of others.
Sound about right?
Thanks.
Sound about right?
Thanks.
#30
