2001 Ram power window
Old 07-14-2015, 07:13 PM
senikc's Avatar
senikc
senikc is offline
Default 2001 Ram power window
I have a 2001 Ram 2500 drivers power window will go down with no problem, frequently when I try to put the window up, I have to repeatedly move the switch for it to go up. I think the switch is bad, how should I check this. It has the express down feature on the drivers window switch which does work.
thanks in advance for any help.
Charles
Old 07-14-2015, 07:47 PM
jkeaton is offline
Dodge Forum Administrator
Moved to the correct section. Try lubricating the window tracks.
Old 07-14-2015, 09:11 PM
senikc's Avatar
senikc
senikc is offline
Actually the window track has nothing to do with the motor not being powered, I can continue to wiggle and jiggle the up side of the switch and the window will close as fast as it opens.
Thanks for the idea tho.
Old 07-14-2015, 09:45 PM
jkeaton is offline
Sorry. Misunderstood. On my 97, the switch could be taken apart and the internal contacts cleaned. Not sure if the 01 is similar.
Old 07-15-2015, 11:08 AM
Moparite's Avatar
Moparite
Moparite is offline
It's probably the motor. Brushes wear out and don't make contact causing the window not to move. Hold the up/down on the switch and smack the door panel with your fist, If the window starts to move it's most likely the motor.
Old 07-01-2021, 03:43 PM
Roshi's Avatar
Roshi
Roshi is offline
I have a 2001, both window cables eventually got frayed and jammed up, had to replace. Common problem it seems but not sure if thats actually the issue for you
Old 07-02-2021, 07:15 AM
jkeaton is offline
This post was from 2015 and the OP has not been back since.
Quick Reply: 2001 Ram power window
