2wd Lift Question
Old 07-19-2015, 07:50 PM
Moose843's Avatar
Moose843
Moose843 is offline
Default 2wd Lift Question
I am looking at a 99 2wd Ram. My idea if I get this truck would be to level and lift about 2" and install 33" AT's. My question is, can I lift the front end up? I ask because I couldn't lift the front end on my 01 ford F150.
Old 07-19-2015, 07:53 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Yep. About 2" is about as far as you can go before you need to start changing other (expensive) parts. I think Hell Bent Steel makes spacers for your truck as well.
Old 07-22-2015, 12:31 AM
zildjian3707's Avatar
zildjian3707
zildjian3707 is offline
i would honestly just steer away from the 2wd drive models. get a 4x4 model and you can fit 33's without changing the suspension, youll just need wheel spacers and if you ever wanna actually lift it high in the future, itll be better suited for that.
Old 07-22-2015, 05:06 AM
duke07's Avatar
duke07
duke07 is offline
Try to check out Daystar. They offer affordable lift kits.
Quick Reply: 2wd Lift Question
