Old 08-05-2015, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
ABS and brake light on
Old 12-08-2011, 10:39 PM
Mr. Wrong's Avatar
Mr. Wrong
Mr. Wrong is offline
I'm hoping someone here can steer me in the right direction. My wife's 2001 RAM 1500 4WD had a 1740 code pop up. Someone told her to change the speed sensor so my father-in-law picked up the one for the rear axle. We changed that this evening, on the ride home the ABS Light and Brake light come on & stay on. And the speedometer stays at 0 until you hit about 20mph. Did we do something wrong when changing the sensor? Or do we need to change the other sensor near the transmission?
  #32
Old 12-09-2011, 08:53 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
I think on your truck, speedo signal is acquired from the sensor in the rear diff. Check the connections to the sensor, and also make sure it is fully seated in the diff. Might have just gotten a bad sensor too.... not like I have never gotten a bum part right out of the box.
  #33
Old 12-09-2011, 11:38 AM
Mr. Wrong's Avatar
Mr. Wrong
Thanks HeyYou....I'll double check the connections. Pretty sure it's seated properly. Could something like getting WD40 or PB Blaster mess up the sensor? Had to hit the old one with that to free it up.
  #34
Old 12-09-2011, 12:04 PM
HeyYou is offline
Shouldn't, its pretty much sealed.
  #35
Old 03-19-2012, 02:49 AM
catton's Avatar
catton
catton is offline
I have a dodge Ram 1500 2001 pick up. I have the following problem: ABS-brake-light comes on after 5miles of driving. What might be the problem? I replaced the PCM, the control module ABS (which is used from a different car), and the rearwheel speed sensor. Any help would be appreciated.
  #36
Old 03-19-2012, 09:40 AM
HeyYou is offline
If you have 4WAL, need to get the codes read, and see what it is whining about.
  #37
Old 05-20-2012, 09:39 AM
postpounder's Avatar
postpounder
postpounder is offline
Default Abs Motor
I have that problem also, But have to ABS motor runs all the time. Even when I turn the Key off.... What th H#*% !!! I had to unplug the motor. Whats up ???
  #38
Old 05-20-2012, 10:57 AM
HeyYou is offline
4wal? You need to pull the codes, and see what's going on.
  #39
Old 07-30-2012, 05:05 PM
dazedconfused's Avatar
dazedconfused
dazedconfused is offline
All right I read all these replies, so this is my problem. I've changed the speed sensor, I've checked the wires from the rear, speedo still comes on at 18 mph,abs and brake warning lights are still on. So now what?
  #40
Old 07-30-2012, 07:38 PM
HeyYou is offline
Need a LOT more information on your truck.... year, 2 or 4 wheel drive, 2 or 4 wheel abs, color, level of window tint, and a few other things I am sure VWandDodge will come up with.
Quick Reply: ABS and brake light on
