Wheel rubbing on lower control arm? Please Help!
Old 06-17-2006, 01:51 AM
Chopper1's Avatar
Chopper1
Chopper1 is offline
Default RE: Wheel rubbing on lower control arm? Please Help!
My thoughts are that the rubbing and the 60MPH shake are not happening at the same time. It's probably been rubbing and it wasn't noticed until the shake surfaced. They might be from the same problem though. The arm bushings worn/loose or an arm bent might be another cause.
Also there is a bolt that sticks out from the spindle that should stop the steering from turning too far. Check to see if it has loosened or broke.
Old 06-17-2006, 02:35 AM
habeba86's Avatar
habeba86
habeba86 is offline
Did you buy the truck new or used? If it was used maybe the previous owner has bigger tires on it, witch caused the rubbing.....
Old 06-17-2006, 05:05 PM
2001RedDodgeRam's Avatar
2001RedDodgeRam
2001RedDodgeRam is offline
I bought the truck used and they already had those tires on there.
The truck is completely stock in the suspension area.
I noticed that I can take a left curve at 60 as long as I do not hit any bumps but the second I hit a bump going 60 with a slight left turn it starts acting up.
Old 06-17-2006, 05:43 PM
20dodgeram01's Avatar
20dodgeram01
20dodgeram01 is offline
do you have a 4x4 or 2x4?? and what size tires?? are you sure you arent just rubbing your fender or inside fender when taking those turns??
Old 06-18-2006, 10:37 PM
shott8283's Avatar
shott8283
shott8283 is offline
4x4 if it looks like it rubs on his lower control arm
Old 06-19-2006, 01:05 AM
fiveliterbtr's Avatar
fiveliterbtr
fiveliterbtr is offline
ORIGINAL: 2001RedDodgeRam
Acting up? The shake? Probably a steering stabilizer worn, bad shocks, or bad tie rods/track bar making it seem to vibrate when hitting bumps...you've never responded to anyone yet if you've checked the front end out...would be nice to know.
Quick Reply: Wheel rubbing on lower control arm? Please Help!
