3rd Gen Durango 2011+ models
DIY: MyGig Lock Pick V.4 INSTALL!
Old 11-14-2011, 03:29 AM
D_wizzle's Avatar
D_wizzle
D_wizzle is offline
Default Have a question
Great information, but my only question is if you don't hook up the factory rear view camera will it still work as it did with the factory settings? I really don't care to have a rear view camera while driving unless in reverse, and i don't want to cut any wires. Thanks
  #22
Old 11-14-2011, 09:10 AM
coldsteel's Avatar
coldsteel
coldsteel is offline
There is no need to cut any wires. It is completely plug and play. If you had a camera before it behaves exactly as it did before the Lockpick. The only difference is that you now have the OPTION to activate the rear-view camera while driving. The same goes for front cam, left and right cam, baby cam. Everything is user selectable options.
  #23
Old 11-14-2011, 08:24 PM
undertow999's Avatar
undertow999
undertow999 is offline
Is the back up camera issue (poor picture quality) only with the 550 or the V4 as well?
  #24
Old 11-15-2011, 04:16 AM
coldsteel's Avatar
coldsteel
It's not the lockpick, but the chassis wiring. Look at this thread, Post 5
https://dodgeforum.com/forum/3rd-gen...p-cam-fix.html
  #25
Old 11-27-2011, 07:46 PM
boosted20v's Avatar
boosted20v
boosted20v is offline
just what I needed. Traded in my 09 Ram for a 2011 R/T. I stripped my Ram in the dealership parking lot. After I confirm it'll work on the 730N I'll be using your directions to install my All Gig! Then again as easy as it is to get the radio out I may just go give it a shot.
  #26
Old 12-06-2011, 04:49 PM
boosted20v's Avatar
boosted20v
FYI for anyone trying to add a first gen all gig HS to an RHR head unit it won't work.
  #27
Old 12-08-2011, 08:56 PM
Creekbuster's Avatar
Creekbuster
Creekbuster is offline
I got my lock pick CHR550 today and have wondered now what happens when you take your vehicle in for service. Not a great time to ask this question I know.
Do the functions show up or should I try to turn the radio off before I take it in?
Does the vehicle computer show any changes. I wouldn't think so.
Thanks the great write up also as I more than likely would not have done this if I hadn't seen it.
  #28
Old 12-09-2011, 04:20 AM
coldsteel's Avatar
coldsteel
1. They have no reason to look for it.
2. Installing it will not void any warranties.
3. If you are concerned that they might figure out it is in there; disable the override so that the radio functions as stock.
  #29
Old 02-03-2012, 09:49 PM
Immokalee98's Avatar
Immokalee98
Immokalee98 is offline
I installed my Lockpik in my 2011 Ram 1500 Crew about 2 weeks ago. install was a piece of cake, but I noticed today when i plugged up my Ipod, i had no control on the screen. it was just blank. Everything else works fine. Any ideas anyone?
  #30
Old 02-04-2012, 05:49 PM
OSUBauer's Avatar
OSUBauer
OSUBauer is offline
Ok, I posed this question in another thread and did not get a fix so I'm asking here. My RBZ plays the audio portion of a DVD but no video (none when in park, moving, none). I do not have rear entertainment system. Will the V4 make the video play? Any reason the video doesn't play as is?
Quick Reply: DIY: MyGig Lock Pick V.4 INSTALL!
