Overhead light
The light should not be staying on as you've described. Has your Dodge dealership addressed this for you at any point?
Kori
Dodge Social Care Specialist
Try the "interior light brightness" vertical "wheel" next to your headlight control on the dash (below and to the left of your steering column). There is a setting that turns on the interior lights...providing you have them switched on...and it sounds like you do have that particular overhead light switched on (press it to switch it off). (I believe if you spin that wheel all the way down it clicks into that setting.) Just spin it up a bit and you should deactivate that.
If you want to turn on the cabin lights that can be a handy thing, but aggravating if you don't know it's there.
Ok, so I get into the truck and all the overhead dome lights come on. I close the door and they all stay on for around 20 t0 30 sec. and then they all go off. I am thinking hey it fixed itself. I start the engine and the lower driver side dome light comes on and stays on ?? Anyone ?
Auggie
Auggie
Trending Topics
After reading comments on this post, it got me thinking about a problem I am experiencing with my '11 Durango (Crew). I had the visor recall done recently and now can not control my interior lights or dash lights using the thumb wheel on the lower left dash next to light switch. The thumb wheel now does not adjust the light intensity on the dash or turn on the overhead lights. The dash lights are stuck in the night time dim mode when the headlights are on and the overhead lights work when doors open, etc, but the thumbwheel controls nothing anymore. The visor lights work as before the recall was done. Makes me think that this issues is a direct cause of the visor safety recall "fix". Anyone else experiencing a problem like this?
