Spark plugs for HEMI
Old 03-26-2009, 12:25 AM
Redone4x4's Avatar
Redone4x4
Redone4x4 is offline
Originally Posted by lxman1
Yep, They do not last. 30K miles for a set of pugs on a modern day engine is crazy. They should at least last 60K.
I have used them in several other applications and they just do not perform/last as they should.
thats all they have to last on the hemi. 30000 and the factory calls for replacement. Stock champions from napa and change em every 30000 mi is the way to go. or you can spend alot more per plug, and still change em out at 30000. i did champions on mine and my buddys' 06.
Old 03-26-2009, 12:50 AM
southernbnb's Avatar
southernbnb
southernbnb is offline
ok so i know that the hemi/poly (lol) has 16 spark plugs. i dont really understand it but whatever. my question is when i was looking at spark plugs on line it reccomended different plugs for the "waste spark ignition". do i need different plugs? or will regular plugs work all the way around?
Old 03-26-2009, 06:01 AM
abarmby's Avatar
abarmby
abarmby is offline
My NGK iridium LZTR4AIX-11 have lasted 37K miles still giving good fuel economy and performance.
Great plug.
Al.
Old 03-26-2009, 08:13 AM
ramhunter9's Avatar
ramhunter9
ramhunter9 is offline
reg all the way around
Old 03-26-2009, 08:32 AM
BEAR's Avatar
BEAR
BEAR is offline
Yeah reg all the way around. When I changed mine for the first time,I bought the truck used and changed the plugs right after I bought it, there were Champions under the coil packs and Bosch Platnum +4's on the wires I guess the previous owner didn't know there were plugs under the coil packs cuz you could tell the champs were original
Old 03-26-2009, 02:08 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
The NGK 5306's are priced about the same as the Champions. I Run NGK's in my Mustang and have always run them in my older cars that I had, 71 Torino GT, 69 Road Runner 440 6bbl, 71 Camaro 388 stroker. Never fouled one or had one die early.
Old 03-26-2009, 02:18 PM
Dodgeboy77's Avatar
Dodgeboy77
Dodgeboy77 is offline
my buddy ran a hemicuda at the racetrack way back and his hemi would only run strong on autolites. anybody tried them?
Old 03-26-2009, 04:37 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
They are a very good plug too, but the only ones that I saw listed for the Hemi are platinum plugs and the Hemi runs best on copper core.
This is one reason why I am going with NGK over Autolites actually. Well, that and I have heard good things about the NGKs in the Hemi and they worked well in my other vehicles.
Old 03-26-2009, 05:29 PM
dodgenitto's Avatar
dodgenitto
dodgenitto is offline
I really need to change my plugs. I am at 69,000 on the original plugs. So they do last.
Edit: 9/14/09, 77,000 and still going
Old 09-14-2009, 12:15 PM
signgig's Avatar
signgig
signgig is offline
Default Champion Spark Plugs
I have had the same set of Champion Copper Plus spark plugs for over 80,000 miles and still running great. Shouldn't that speak for itself. Those who like NGK or Bosch think that if they cost more they must be better, I don't think so. Also, you are supporting companies outside of the United States. Champion has been around for a very long time with a positive reputation. The manufacture use Champion because they are reliable in quality and a great value.
Quick Reply: Spark plugs for HEMI
