Old 08-05-2015, 09:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
how do you reset the ecm?
Old 07-09-2010, 03:20 PM
badblackram06's Avatar
badblackram06
badblackram06 is offline
Default how do you reset the ecm?
How do you reset the computer on an 06 ram? I have searched and have not found it. I want to try by pulling the fuse and cycling the ignition but i don't remember how to do it. If someone can help me out I'd appreciate it.
Old 07-09-2010, 03:38 PM
AWE Daniel's Avatar
AWE Daniel
AWE Daniel is offline
Thanks goes to hammer
1) Pull fuse #19 or #23 or #31 (vehicle year dependent, but it's labeled)
2) Close door and buckle seatbelt (technically you don't have to buckle the seatbelt, but it helps to stop all unnecessary chimes)
3) Put key in ignition and turn to "on" and wait until all chimes stop (on...not start!)
4) Turn key to start and hold until you hear 2 chimes (I think it was about 15 seconds or so.
5) Turn key off
6) Re-install fuse
Old 07-09-2010, 07:23 PM
badblackram06
i did this but only heard 1 chime which was the air bag light coming on. Would it be different on certain year models??
Old 07-09-2010, 07:44 PM
RedTruck-VA's Avatar
RedTruck-VA
RedTruck-VA is offline
Take the cover off of the fuse box. Under the top is a diagram of the individual fuses. Look for the PCM fuse, mine I think is #16. Remove the fuse and do as mentioned above.
Old 07-09-2010, 08:54 PM
badblackram06
I took the right fuse out. mine was #31. I did everything mentioned but instead of hearing 2 chimes within, lets say 20 seconds, I only heard 1 chime and that 1 chime was the air bag light coming on during which i still had the key held at start. I even held it close to a minute hoping to hear another chime. I've done it 3 times but get the same results. I do appreciate the help though.
I have been told that some newer model vehicle's computers have to be reset using the scan tool. I dont know if that applys to mine or not.
Old 07-09-2010, 09:02 PM
Atomic Punk's Avatar
Atomic Punk
Atomic Punk is offline
Sorry read ur post wrong
Old 07-09-2010, 09:25 PM
RedTruck-VA
Reboot is just is like restarting a computer. Reflashing takes the StarScan to reinstall the operating system. If the PCM has been rebooted on my 03, the first time I try to start the engine, it won't do anything when I turn the key. The second time I turn the key it then acts normal and starts. That's what I call a reboot.
Old 07-09-2010, 09:37 PM
badblackram06
Ah i see. Mine cranks everytime after i do it so it may not be rebooting. I will see if this works on my buddies 04.
Old 07-09-2010, 10:30 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
just for the sake of clarifying, ECM's came on CTDs and PCM came on gassers
Old 07-09-2010, 10:51 PM
badblackram06
ha yeah my mistake. I caught it right after i posted. I should have known since i had been pulling the PCM fuse.
Quick Reply: how do you reset the ecm?
