4wd indicator light not workng
Old 01-28-2011, 04:49 PM
atv1988's Avatar
atv1988
atv1988 is offline
Default 4wd indicator light not workng
Ive done the cluster self check and the light still does not illuminate which means its in the cluster itself right or could it still be the senser on the t-case. its a 05 hemi 1500 btw
Old 01-29-2011, 06:05 PM
gordie580's Avatar
gordie580
gordie580 is offline
how do you do a cluster check on an 04? I also want ot get my 4x4 light to work. and I want to check make sure it isnt the sietch in the manual 4x4.
Old 01-30-2011, 01:30 AM
atv1988's Avatar
atv1988
atv1988 is offline
Mine is an 05 but should still work...press and hold the trip meter button then turn the ignition to on but dont start the truck and let go of the button.
At the end of the test it will display C-Code and any codes stored if no codes you will get C-Code 00 00
Btw Is u seach any of weedahoe's posts he has a link where u can download a service manual for ur truck
Old 01-30-2011, 04:05 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Yep, the links are in my signature. Feel free to download and do the checks
Old 02-03-2011, 03:05 PM
atv1988's Avatar
atv1988
atv1988 is offline
So can anyone confim my suspitions or no?
Old 02-03-2011, 07:51 PM
mikbimdre's Avatar
mikbimdre
mikbimdre is offline
mine does this too, sometimes it works, sometimes it doesn't. It seems to work more ever since I lifted it. Not sure of the reason either cause the light obviously works. It must be a bad relay or switch that is intermittent. Either way you can tell if it is working cause 2wd in snow = no go, 4wd in snow = go anywhere
Old 02-12-2011, 11:42 PM
Wanderer's Avatar
Wanderer
Wanderer is offline
I had the identical problem, it was a simple and cheap fix. The part is called position sensor, cost about 32 bucks and took 15 minutes to replace. The sensor goes in the front of the transfer case. Make sure the oil ring is reinstalled.
Old 02-13-2011, 06:48 PM
atv1988's Avatar
atv1988
atv1988 is offline
Yes I know where the sensor is and how to replace it... What im trying to do is figure out why the 4WD light still doesn't light when I do the trucks self diagnostic because as far as I know it still should and why it doesnt? Thus I dont think its the sensor
Old 02-13-2011, 06:59 PM
SilverHemiDan's Avatar
SilverHemiDan
SilverHemiDan is offline
what are the chances of it being the light...very slim
my guess is the sensor,very common problem..I replaced mine,too
Old 08-24-2011, 01:41 PM
Bludodge05's Avatar
Bludodge05
Bludodge05 is offline
When you say position sensor, is it the Crankshaft Position sensor (CKP) or the Camshaft Position sensor (CMP)? I may just be lost all together.
Quick Reply: 4wd indicator light not workng
