NO BUS... How to fix?
Put your key into the ignition. Press/hold your Odo reset button and while holding turn your key to the start position but don't crank. release thereset button.
This puts your odometer in a diagnostics check. If nothing happens, your odometer is bad. if your odometer fails one step, like not sweeping one of the needles, it's bad.
If you get no power to any part of your truck, well check your battery, but your ignition switch could be bad as well.
All your stuff goes through your cluster. It's what's called a decoder.
Trending Topics
Pull the battery power, turn on the headlamps to drain of ALL residual power, pull the connectors from the main PCM on the passenger side firewall, check all the connections there for corrosion, If any are broken, you're probably SOL----
I remember when I first joined the forum, there were a number of giuys with your year truck having corrosion problems at the main PCM
Goodluck!!!!
Goodluck!!!!
Dodge Ram 2500 Van 02. No Bus after battery ran out and recharging.
Clean battery terminals with wire brush; remove mattress at the driver seat, near the foot brake, then shake all wires and connectors. Do twice and make sure battery's wires are 12.4+V.
It works. Good luck.
