In-Dash Navigation System Problem
Old 01-08-2012, 12:06 AM
John Hixson's Avatar
John Hixson
John Hixson is offline
Default In-Dash Navigation System Problem
I am the original owner of a 2006 Ram 3500 Cummins 5.9l. I have just begun to have problems with my in-dash navigation system (Code REC). After a short period of driving I will get a "NAV Message" warning telling me there is a "disk error". If I turn off the ignition and restart, things are OK for a few miles/minutes before I get the same error message again. Once the error message shows up the nav screen is blocked by the message window and cannot be used for navigation. Only turning off and back on removes the message. I've tried removing and reinstalling the nav DVD, but this only temporarily restores the system until the next "disk error" message.
Has anyone else experienced anything like this and if so what did you do about it? Thanks. John Hixson
Old 01-09-2012, 09:46 AM
Brandon Anderson's Avatar
Brandon Anderson
Brandon Anderson is offline
First thing I would try is a lens cleaner disc. If that doesn't help, I would then try a different/new nav disc. If that fails to remedy the issue, then it's time for a new REC unit.
I'm currently using a burned DVD-DL, and the first two would not read for crap. Third disc I burned at the lowest possible speed, and it's never given me a single error. Keep that in mind if you're not using an OEM disc.
Old 01-25-2012, 04:37 PM
SMOKINRED2500's Avatar
SMOKINRED2500
SMOKINRED2500 is offline
back in 2006 When i bought my 2006 2500 ram Cummins 5.9l i removed my oem nav system and replaced it with a pioneer system so i could run video to the back seat for the kids. i still have the original unit and its for sale if you are interested
Old 01-25-2012, 05:14 PM
Brandon Anderson
How much?
Old 01-28-2012, 06:44 PM
SMOKINRED2500
I would want 400 for it. I have the unit, disk and owners manual.
Old 01-29-2012, 01:18 PM
houseoftoes's Avatar
houseoftoes
houseoftoes is offline
Dont know if this might help but I know they came out with an update for the NAV system. I was notified by the dealer and the new disc/upgrade costs $150.
Old 02-20-2013, 09:14 PM
steve5chang's Avatar
steve5chang
steve5chang is offline
I had the same problem yesterday on my 2006 Durango Hemi. I took out the CD and shot some air from a dust canister. It seems to work..no more error messages. Keep you guys posted.
Old 11-04-2013, 10:16 PM
toddwilcks's Avatar
toddwilcks
toddwilcks is offline
I'm having the same problem, but I cannot get the disk to eject. I can hear it trying to eject, but the disk does not come out. Any tricks to getting the disk to eject.
Quick Reply: In-Dash Navigation System Problem
