buying 07
Old 07-30-2014, 09:23 PM
dully's Avatar
dully
dully is offline
Default buying 07
im buying a 2007 3500 with 354000 miles these codes are coming uo ,help me if possible po876 po489 po2080 po2084 po245b po2453 po244a po0471 n po0037 . he keeps talking about a little black box on the frame . truck is mint new dodge trans new good year tires very clean 9400 .00 should I be worried or go for it . everything works
Old 07-30-2014, 10:19 PM
RamRod37's Avatar
RamRod37
RamRod37 is offline
Well Heres the code meaning but being A Cummins that's as far as I can Go With Help On This Issue
•P0876 Transmission Fluid Pressure Sensor/Switch “D” Circuit Range/Performance
•P0489 Exhaust Gas Recirculation "A" Control Circuit Low
•P2080 Exhaust Gas Temp Sensor Circ Range/Perf Bank1 Sensor 1
•P2084 Exhaust Gas Temp Sensor Circ Range/Perf Bank1 Sensor 2
•P0245 Turbocharger Wastegate Solenoid A Low
•P2453 Particulate Matter Trap Differential Pressure Sensor Signal Performance
•P0471 Exhaust Pressure Sensor Range/Performance
•P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
Old 07-30-2014, 11:09 PM
dully's Avatar
dully
dully is offline
it does have a new reman, trans 8 months ago from dodge , but those all seem easy fix . . but what is a little black box he keeps talking about on the passenger side frame rail ,truck runs great I have a 2005 dodge 2500 4 wheel drive now with 96000 miles on it I just don't like it ,its to high .lol I need a step ladder to get into my tool boxes lol
Old 07-30-2014, 11:15 PM
dully's Avatar
dully
dully is offline
what is the heater control curcuit
Old 07-30-2014, 11:20 PM
RamRod37's Avatar
RamRod37
RamRod37 is offline
Like I said In not A Cummins Mechanic So I Cant Help But If I was Going to guess id say heater control circuit is glow plugs circuit but I will leave that to Someone That Knows Cummins Well
Old 07-30-2014, 11:32 PM
dully's Avatar
dully
dully is offline
im suppose to buy this truck tomorrow , its great shape runs great and everything things works . I know I will have to repair things .I,m just trying to figure if its worth it .the 1 code that comes back right away is the 037
Old 07-31-2014, 12:28 AM
RamRod37's Avatar
RamRod37
RamRod37 is offline
well What The KBB Or NADA Value Show It With The Options it has and the mileage
Old 07-31-2014, 08:20 AM
dully's Avatar
dully
dully is offline
between 14500 and 17800. thanks
Quick Reply: buying 07
