4.7 engine noise
4.7 engine noise
i have a 05 dakota 4.7 that i recently swapped the engine to an 05 ram 4.7. problem with my old 4.7
-very loud on startup clicking, light knocking sounds like a diesel on startups
-losing a tremendous amount of oil 5L a month on oil.
-cracked head around the timing chain tensioner bolt/very loose chain on the left head
-tremendous amount of blow by
problem with the new engine is it is very loud on startup clicking, light knocking sounds like a diesel on startup.i did a visual inspection of both heads and checked the chain for any looseness before i had it installed and saw nothing wrong with it.
this is the only problem with this engine is that it sounds so bad on cold start ups like my previous engine but has no oil issues that i know of yet and drives like a champ. i spent 1475$ on the engine from a salvage yard who said they fired it up and everything sounded fine before i bought it. then i spent 2300$ on getting it installed and they said it started fine. but it sounds so bad on startups.
any remedies of this problem as i have asked this question in the dakota section with little response now that it is a ram engine i thought i could get some input from you guys.
I assume you changed the oil and filter but maybe a good additive will help if not using a synthetic. I use Justice Brothers engine treatment with regular oil. It bonds to the metal. It sounds like you just need better oil flow to the head. If this doesn't help you might want to check the sump screen.
try taking the bracket off that is next to the oil pan that bolts up to the tranny. Look in side and see if it has any damage. It's possible that the torque converter bolts might be hitting it if you didnt replace them with the right ones. Another thing could be the plate that attaches to the bottom of the block in the oil pan could have been bent unless it came already installed in the engine when you bought it. You might also want to check all the pulleys. the A/C condenser makes a pretty loud knocking noise that sound like a diesel if the bearings have gone out. I actually have to change mine this weekend because thats the sound its making at the moment
It's amazing what sounds these and Ford 4.6's will make if the oil flow to the head isn't good enough. Mine used to have a slight upper end knock on start-up when Dodge was changing my oil for free up until about 40k. They used just regular oil. After that, I started to add the Justice Brothers oil treatment with metal conditioner along with regular oil and I no longer have any noise on start-up. The only sound to be heard on start-up is the fan. Try Valve Medic to clear up any passages.
Trending Topics
