Hello from Georgia
Hello from Georgia
I have 2003 dodge ram 1500. I'm looking for some answers about the ABS brake system. My brake pedal went to the floor recently with out warning,
I have replaced master cylinder, brake pads on front, new calipers on front and new pads on rear with new rotors on rear as well.
Anyone have thus problem, if so what was the fix?
I am afraid to take my grand kids anywhere in truck due to this problem
I forgot to mention, this problem happened before the brake work was done..... A mechanic said it was showing a code and he erased code before I could get the number... Said the ABS was running continuously. Brake pedal went to the floor several times before brake work was done......
Last edited by Allen M; 09-27-2015 at 09:51 AM. Reason: made corrections and added some more info
I wonder how many actually go pay the dealer to bleed ABS. Not disputing that it's the right thing to do, but to shell out big clams for a simple bleed? I just bleed the 4 lines, personally.
Trending Topics
Continued brake problem. ABS
I forgot to mention, The brake pedal went to the floor three times prior to brake work being done...... Brakes were and have been working fine..... Going 40 mph and the guy in front of me hits his brakes, I hit mine and nothing.... All the way to the floor and had to lock emergency brakes up and spun all the way around..... After the brake work was done the problem has happened three more times.... one time was, pedal going to floor within an hour of the first time
Plus I had brake shudder in the front.... Right about the time I had received all my parts is when the problem began with pedal going to the floor.... 239.000 miles on truck and never replaced pads until now.....
If you know what the problem is, why don't you share the info with me.......
Forgot to mention... Two days before my parts were to arrive is when the brake pedal went to the floor......
Hope this answers your questions as to the repair
Either your brakes are not bled properly, or you're still losing fluid somewhere. Take all the wheels off and put it up on stands. Press the brake hard, use something jammed between the seat and brake to hold it down... then crawl around and look everywhere the lines go. Check the back of the calipers, etc. Also around the MC, to see if there are any leaks. If no leaks, bleed them again in proper sequence.
