Transmission Fluid Change HELP...
I want to completely change my ATF, but had a couple of questions....
The Amsoil website says that the pan holds around 6.6 quarts for initial fill and 14.8 for a full fill. If I were to change the fluid using the method where I disconnect the cooler line and pour fluid in while car is running and pumping out, wouldn't I need the 14.8 quarts to completely flush and fill? Also, has anyone changed their ATF over to Amsoil? Any improvements noticed?
The initial fill is after you remove the pan which drains it's content. That's necessary to do if you want to replace the spinoff and flat filter.
I'm not sure what the exact total amount is. I did the cooler line trick a couple of years ago, most people suggest buying a couple extra quarts just to make sure you get all the old oil out.
I used Castrol and Mobil 1 ATF4.
Do you think it is necessary for me to purchase 15 quarts? How many did it take when you did the cooler line trick?
on
buy 17 - 20 qrts... use the tans to pump out 7.. drop pan and replace filters.. replace pan.. add 7 qrts... use trans to pump new oil from pan into the trans and push out the bad... add another 7 qrts... drive around to operating temp.. top off as needed while hot... use any extra to flush brake lines be sure to have lots of shop rags and i would recommend using oil resistant gloves as well
Trending Topics
I used 16.25 Quarts
I just did the cooler line DIY last weekend. I bought 19 quarts of the Mopar ATF+4 and used 16 of them + the 1/4 quart left over from when I did my tcase the prior weekend. I got nervous about running it too long and feared running it dry, but after I was done and refilled everything, I guess I ended up pretty good given my system holds a total of 17 quarts.
I ended up using the other 3 to flush/refill my power steering.
