Suspension Expert Needed
Clunking and popping during braking initiated me to replace the lower control arm bushings. I had a local shop replace the bushings and I think they stretched the eyelets out so now forced to replace the whole arms. New arms installed and not sure why be there is a gap between the ears of all 4 LCA pivot points and clunking is worse now than before. I torqued the LCA pivot bolts to 200Foot lbs. Wrong LCA's? my truck is an 03 late production RWD Ram 2500 with Heavy Duty noted on back of tailgate. Its almost like they're the wrong arms for the size of the truck. What gives. Please take look at the video and feel free to comment or make suggestions accordingly.
There should not be ANY side play in the control arms.Why did the tech widen the pivot points for the bushing?Is he a ASE certified chassic suspension.He should have known better.Shims to tighten up the sideplay,maybe.I would go too the dealer for R&R and have the bill paid from the tech that screwed it up.Get rid of the rubberbushing and go with polyurethane bushing,Energy Suspension.Concider a teardown of the front end,for inspection.If there are any questionable areas(welds-cracks in the mounting,R&R....
agreed no play at all, seems as if they used the wrong bushings or wrong parts in the correct box installed on the arms, that play will really be annoying when towing that sea ray down hill & on the brakes. I always press out the old with new ones but that would be frustrating since its boating season
So strange. The replacement MAS arms do the same thing. There is no gap between the ear as originally thought. The center bushing in both the NAPA bushings as well as the MAS arms are moving. I have since tack welded the bushings in the original arms and sent the MAS arms back to Rock Auto. Pauling dodge had me drop it off and they recommended replacing the arms with factory ones. Ouch they cost more than this truck is worth. Not sure what to do but I do know the movement is inside the bushings and not the ears as had originally thouht . I guess this is it as I don't have the funds to spend $1200 in arms.
Trending Topics
beech 2000.Sorry for the insult.it was un-intended.Didn't know that DODGE was at fault for problems your dealing with.I don't have a suggestion other than good luck.At first I thought it was a hurry up job from a tech loaded up with customer waiting & 20 more before lunch if he's lucky.I know from experience.Again Sorry...
I haven't located any polys for RWD 2500's Do you have vendor in mind and respective parts numbers? Truck is 2003 RWD Ram 2500 manual trans
