1st gear waaaay too tall?
I have 2010 TRX4 with the 4.7, which I think has the 3.92 gearing.
I never really noticed or cared until I both moved to the mountains AND started towing. 1st gear goes redlines near 60mph! And if you know this engine, you know it has NO power until around 3000rpms. So if I'm starting from a stop, going uphill with a trailer, I often can't go at all. It just doesn't have the power down low. I know the engine has power, but the insanely poor gear choices Dodge made doesn't let me access it.
Does anyone notice this or have any suggestions?
I live at 7200 feet, so I'm already down almost 30% on power, so I know that doesn't help, but that doesn't change the ridiculous gearing.
Kepp in mind, before downplaying the 4.7, that it has as much power as the large engine did just a few years prior, and gets about 8mpg better. It has plenty of power, it is just not reachable until above 30 mpg due to poor engineering choices.
FWIW, I bought it living at sea level
on
Trending Topics
on
I suspect he's got too much trailer behind him.
In the old days, if you had a small engine like a 4.7 (318 CID) you got it with a manual and got granny gear 1st. Most of the vehicles from that vintage used for towing had big blocks with gobs of low end torque. We had 383s. 440s. 454s, 460s etc (Even the buick 350 I have in my wagoneer is rated at 360 lb-ft at 2600 rpm). My first real towing vehicle was a 1966 chevy pickup with a 292 six banger one barrel carburator (oil bath filter), granny first and a 4.10 rear, that truck was a stump puller.
