jumper the relay and see if the fan comes on. pins 30 and 87 i believe. if it doesnt, check the wiring going to the fan to make sure none of them are broken. if they arnt, then the fan is bad
Thanks for the tip. But I'm going to need a little more info, where are the pins located that your talking about.
Kindest regards,
Tom
If it had an accessible relay, it will be under the hood in the power distribution box where the fuses are. It should tell which relay it is on the bottom of the cover. The relay will have the pins numbers on the top usually.
I have an 07 dodge caliber and my double fans not coming on and the ac not blowing cold checked the fuse was good hooked up my fans direct and both work hooked the compressor direct and blew cold air and it's not over heating either anybody that can tell me what to check next
Do your fans come on when the temp gauge gets about 1/2 way up? This is about where they come on without the a/c on. If so, then your a/c circuit. Does the snowflake switch light up when you turn on the a/c?
Hello I'm new in the forum, I have an opposite problem! My fans are always lit with a cold engine, you would know tell me where control relay? I can not find them.
