more acceleration as foot is removed from the accelerator
im having a really strange issue I've never come across before. when I start the car it runs rough (just suddenly happened with no warning). after that when the car is put into gear it wants to jump forward. as I push down on the accelerator the car will get to around 15 mph with the petal pushed all the way down and the rpms don't go pass i'd say 2000 (no tachometer). The more I let my foot of the accelerator the rpms increase and it will pick up some speed very slowly. right before the accelerator is completely let out is when your get the most acceleration. its similar in reverse. please help this is my only transportation at the moment and I can't afford for it to be out of commission for to long. thanks in advance.
I concur - it sounds like either the calibration of the TPS or you need a whole new Throttle Position Sensor. Look for the lightning bolt between two lines on your dash warning lights. AutoZone and some other stores will scan your computer for codes and can tell you if it's that sensor (if you can safely drive to the store to have it checked).
Locally, that is likely about a $85 an hour to diagnose, and another hour to install if I had to guess what the dealer would charge, plus the TPS sensor cost. Let us know what you find out. Good luck.
