Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
High speed blower motor
Old Mar 19, 2014 | 09:58 PM
Joes 02 Ram's Avatar
Joes 02 Ram
Default High speed blower motor
The high speed on the heater blower motor won't work. I replaced the resistor and it still doesn't work.I think it is the switch. I can't find a wiring diagram or a service manual for the 2010 Dodge Caliber to help me with this problem.
Old Mar 22, 2014 | 09:35 PM
lxman1's Avatar
lxman1
Site Moderator
The 2007 service manual is up above in the Read First section of this forum for a free download. I don't know if the control wiring is the same on the switch since the 2010 went to the servo driven blend doors instead of the cable actuated system of the 07-09 cars. Sounds like the switch since the resistor pack is usually bypassed in the high position.
Old Mar 26, 2014 | 02:18 PM
steak59's Avatar
steak59
Yeah, usually your problem is going to be the switch. I believe it is the whole control module in your case.
Old Mar 26, 2014 | 08:46 PM
Joes 02 Ram
Default Switch
Yeah, it probably is the switch. It could be a burnt wire also. I will look at them when I put the new switch in.
Old Mar 26, 2014 | 09:05 PM
lxman1's Avatar
lxman1
Site Moderator
Let us know how it goes.
Old Apr 29, 2014 | 05:05 PM
johnnyelectron's Avatar
johnnyelectron
I haven't looked at the wiring diagram, but my van used a relay for full voltage, bypassing the resistors when in highest speed fan. Maybe relay is toast?
