Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Best way to use Kick down Dodge caliber-2007
Old 02-25-2016, 12:32 PM
Helena-64's Avatar
Helena-64
Helena-64 is offline
Default Best way to use Kick down Dodge caliber-2007
What is the best way to use kick down?, I had no Idea what this was and
did not understand why is not going any faster, It has been 2 times when
i give too much power too fast. I have not drive automatic before. But loving it!
Old 02-25-2016, 12:45 PM
jkeaton is offline
Dodge Forum Administrator
Automatic transmissions kick down to a lower gear to make use of the greater power delivered at the engine’s higher rpm; this typically occurs when you attempt to accelerate from a constant speed, as if to pass.
Kick down just means the transmission is changing gears based on throttle input. If you're in a higher gear, say just cruising along and you press the pedal hard and fast enough the transmission will "kick down" into a lower gear to provide more acceleration. There is no "best way" to use it, it's all automatic.
Old 02-25-2016, 12:57 PM
Helena-64's Avatar
Helena-64
Okey, thanks is it best to use when driving up hill, mountains? to give more acceleration?
Old 02-25-2016, 01:39 PM
jkeaton is offline
You don't "use" it per se. It's a built in function of the transmission. The vehicle will use it when it needs to based on driver input. It is to give a boost of acceleration during passing conditions or you want a quick increase of speed.
Old 03-11-2016, 04:17 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
The Caliber uses a CVT transmission. it doesn't have gears like most transmissions. It has two self adjusting pulleys and a metal style belt. It is designed to keep the rpm at peak power depending on how far you push the pedal. It is a bit weird feeling at first, but you get used to it.
Quick Reply: Best way to use Kick down Dodge caliber-2007
