07 Caliber Complex Keyless Entry Issues
on my 07 Caliber. I have an issue with what seems like my keyless entry. when i am in range for the remote to work, my lights will start flashing as if i have unlocked it. I have not pushed the unlock button and nothing unlocks. the "hazard lights" flash in sync on the dash like with you unlock it.
If they keys are not in range it will not do it. It's intermittent on frequently they will flash. once i put the keys in the ignition, it will not flash no matter how long i sit there with it off and pulled out enough the sensor not activated.
This has been happening since 5/9/2016.
Sometimes this occurs my lock/Unlock/panic buttons will not work on the car, even standing next to the door, and sometimes it will work like normal but flashing.
Some suggested i reset the relay fuse, i cannot figure out which one it is.
Some suggested i get a replacement remote.
Some suggested the issue is module communication.
Before i spend a ton of money on a mechanic and key, i wanted to see if anyone else has This issue and what they did to fix it. Or if anyone has any suggestions.
*Note: i've notice the more i move the remote(I.e. lanyard) the more frequent it flashed while i walk up to it. If it's in my purse or directly in my hand with little movement, it flashes less. I do not have a spare key to test.
