DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 11-27-2007, 11:26 PM
blackikon blackikon is offline
Default Help PLEASE!! Misfire Codes
I am getting codes P0302 and P0304 for the past several months. I have changed plugs multiple times and it gets better for a few weeks. This past week i changed the oil and plugs and a few days after it started 'stuttering' worse than ever. It is almost stalling it has gotten so bad. I spoke to a couple techs and they insist this is an electrical problem. They suggested the ignition coil. I changed it out this evening, along with fresh plugs and it is the same. It's no better than before. I need some help here guys. I got low dough and this is my wife's daily driver with our two small children. I need to fix this asap. Thanks in advance.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-27-2007, 11:59 PM
dishdude2k dishdude2k is offline
Vehicle: 2001 Dodge Ram 1500
Default RE: Help PLEASE!! Misfire Codes
little info on what kinda vehicle.. and engine would be good.... but sounds to me like you need to have the fuel pressure checked... low fuel pressure will make it act like that
__________________
01 Dodge Ram 1500 5.2 auto w/ 3 inch body lift and 3 inch suspension lift
99 Caravan 3.0
Old 11-28-2007, 12:04 AM
Sorry, 2004 3.8L V-6, Grand Caravan w/ 88,000 miles
Old 11-28-2007, 12:06 AM
I too thought about the fuel pressure/filter, but when I posed the possibility to a Dodge tech he shot it down as not possible to be a fuel issue and throw a misfire code. Is this so or is it possible for the lack of fuel cause the ECM to through a misfire code?
Old 11-28-2007, 09:10 AM
it IS possible.. i have put in fuel pumps before for this issue.. if the engine is gettin just enough pressure to run.. but not run properly.. its not getting enough fuel to fully pressurize the fuel rail... which in turn not all cylinders are getting fuel to fire that cylinder.. hence.. misfire... check fuel pressure.. just to rule it out.. just because hes a dodge tech.. dont mean he knows all about every vehicle that comes in the garage...
__________________
99 Caravan 3.0
Old 11-28-2007, 09:25 AM
Where do i get the pressure tested? I may just replace the fuel filter and see if that helps, I hope its not a pump. . .$$$
Old 11-28-2007, 09:26 AM
Old 11-28-2007, 07:48 PM
you can test it yourself.. get a standard fuel pressure guage.. and check it at the rail.. have to look it up to see what the range should be for your vehicle.. also.. i THINK there is a TSB on this vehicle with spark plug wiring.. check that out as well.. make sure none of them are arcing.. best way to do this is at night.. no lights.. start the vehicle and look under the hood.. if you see blue sparks.. you got crappy wires.. and what kinda plugs did you put in it?
__________________
99 Caravan 3.0
Old 11-28-2007, 08:20 PM
i replaced with OEM plugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
