How to drain a Caravan fuel tank?
How does one drain a caravan fuel tank (specifically 1995, 3.3l)? Can it be done without dropping the tank, as it is a FULL tank? Would I be able to siphon the fuel with the tank in place? My problem may be a slug of water. Any assistance is appreciated. Thanks!
I will be checking the fuel filter to see if it indicates water/trash.
I disconnect the fuel line at the injector raill, install a hose to a gas can then using a paperclip, jumper the fuel pump relay socket. works GREAT!!!! This is how I get gas out of cars I'm going to junk
be aware, if you run vehicles with E10, you can't have water in the system. Ethanol takes care of that problem (unless someone doesn't like you and used a garden hose to fill your tank
Trending Topics
Thanks again Tizzy1. I thought I had my problem resolved with a fuel filter change. I did not find any water (did not drain tank as it is full, no water at filter). I thought if there was water, that it may have come from a truck tank cleaning, etc. The fuel station said they had not had any complaints. I test drove the van a couple of times and it ran great/normal.
My wife drives the van to work this morning and while on cruise control the engine revved up and lagged a couple of times (~18 miles driven) just before she turned onto an access road. Then as she tried to accelerate the van kind of missed/studderred. Then the same miss/stutter when starting from a traffic signal. I am going to go and trade her vehicles.
Any thoughts - fuel issue or maybe ethanol based fuel has washed some debris loose? Ignition issue? Even a transmission issue?
(New plugs/wires a few weeks ago) Again, all assistance is appreciated. Thanks
