2000 Grand Caravan Power Outlets not working
Old 09-19-2012, 01:02 AM
vegascoug's Avatar
vegascoug
vegascoug is offline
Default 2000 Grand Caravan Power Outlets not working
I've been trying to find a fuse diagram or some info online for this and am drawing a blank, so I am looking to all the experts on here.
I have a 2000 Grand Caravan Sport with both outlets (front and back) not working, not sure if they both went out together or one by one, but both are dead. I found the relay under the hood and replaced it, still no dice. I even switched the relays with the starter and the lighter/outlet and that didn't work.
I was told by someone that there might be a fuse behind the actual lighter, an in-line fuse that can blow. True?
Or is there another fuse inside the car under the drivers side dash? I see lots of posts on FixYa and other sites relating to this issue but I have yet to find a fix. It cannot be THAT difficult can it?
I am trying to sell it and that is one thing that isn't working that I really want to work before someone comes to look at it. Cell phones are too common to try and sell a car without a "charger" feature
Old 09-19-2012, 02:03 AM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Have you checked 20amp fuse #4 in the PDC under the hood?
Old 09-19-2012, 11:53 AM
vegascoug's Avatar
vegascoug
Default Thanks!!!
I have been messing with that for a week, found the relay but never found the fuse...guess it would help if I would have read all the labels first...DOH! 20A fuse blown, replaced, all is good again.
Old 09-19-2012, 01:09 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Yes probably but hey, you fixed it. Congrats. If it wasn't the fuse you'd be chasing wires for another week.
Old 02-17-2013, 11:56 PM
kamnet's Avatar
kamnet
kamnet is offline
Apologies for grave digging a topic, but thank you for posting this! I just bought at 2000 Grand Caravan that had the same issue, a Google search lead me right to this post. Sure enough, same blown fuse.
Old 10-18-2016, 09:34 AM
georgi's Avatar
georgi
georgi is offline
Dodge caravan SE 2001.
I was inflating the tires with eclectic pump powered from the power outlet (cigarette lighter) and a bit later it stopped. No power to the front Power Outlet and the radio. BTW I used this pump on the van hundreds of times.
I found fuse #5 20amp was blown. Replaced it and everything is working.
Attached.
Old 05-14-2019, 07:48 PM
Eder Rouse's Avatar
Eder Rouse
Eder Rouse is offline
Default The same problem
Hi.
My name is Eder, from Mexico
I have grand caravan 2000 and replace all fuse (inside and under hood) but the outlets not working
My inglish not good.
Quick Reply: 2000 Grand Caravan Power Outlets not working
