p o455 engine code
p o455 engine code
I have a 2003 caravan first i got the 0442 code and I replace the gas cap and now im getting the major leak code. i need to change the LPD valve. does any one where and how to replace it. and how much the part is from the dealer? it this a dealer only item because local places dont carry it
RE: p o455 engine code
I think this code has to be reset with a scanner or with so many key-on cycles. #7 is what the pump is supposed to look like? It may be near the vapor canister #3? Dealer only item and lists for around $115...you can get it cheaper on the web at www.makeitmopar.com
[IMG]local://upfiles/21718/D5EAF116774C49978F9EA861FB0832C0.gif[/IMG]
Before you buy anything, check with your stealership to make 100%
sure your problem isn't covered with federal laws.
I had a older Dodge pick up that the stealership said it needed a new
complete charcoal filter system and I don't remember what the price
they told me it was going to cost..
I thought I'd try and save some money and went to NAPA to get one.
NAPA said they would gladly sell me one BUT if I had less than 50K on
the truck, it was a stealership FREE replacement..
When I went back to the stealership and told them I needed it replaced,
they had a BIG grin on their faces UNTILL I told the #astards it was 100%
covered! They replaced it and sent me on my way, FREE!
DON'T EVER TRUST YOUR DEALERSHIPS WORD ON ANYTHING!
