RE: Grandcaravan stalling
I had a similar problem with my '96 GC and I don't know if your problem is the same.I had no check engine light or OBD codes.
On mine, the idle bypass passage was gummed up. I was told that this is a common problem. If you remove the rubber bellows that goes into the air intake you can see the black buildup inside the tube. The throttle butterfly is closed during idle and the engine gets its air through the idle bypasspassage which is controlled by an idle solenoid. Thispassage gets gummed up and the idle air gets cut off. The best way to clean it out is to remove it and clean it in parts cleaner but I heard that carb cleaner spray works too. Good luck
