Notices
Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
Low tire light goes on and off
Old 08-20-2014, 09:17 AM
lspringman's Avatar
lspringman
lspringman is offline
Default Low tire light goes on and off
I have a 2010 SE. The low tire light came on last week so I stopped at Discount Tire, they aired up the tire that was low, and after driving for a minute the light turned off. Then this week the light started coming on, then would turn off (sometimes right away, sometimes a couple minutes later). Then it would turn on again and then off again...over and over.
Any thoughts on what could be the issue?
Old 08-20-2014, 11:48 AM
DodgeCACares's Avatar
DodgeCACares
DodgeCACares is offline
lspringman,
I'm sorry to hear of your tire pressure concern.
Have you manually tested the tire pressure on all 4 tires prior to driving? Does the lamp indicate a particular tire losing air? Does the light come and go regularly now?
Do you install winter tires during the winter months?
Old 08-20-2014, 11:51 AM
jkeaton is offline
Dodge Forum Administrator
Check the tire pressure.
Old 08-20-2014, 02:40 PM
lspringman's Avatar
lspringman
Originally Posted by DodgeCACares
lspringman,
I haven't manually tested yet since it seemed strange that it was going on and off by itself. It's been a few days since it started doing it and so far it's been pretty consistent.
We do not install winter tires. I'm in Texas so our winter is probably only 2 weeks long
Old 08-20-2014, 03:27 PM
jkeaton is offline
You could have a slow leak. First line of defense is to actually check the pressure yourself. If the pressure is good, we can move on from there. Check the pressure and report back.
Old 07-24-2015, 04:58 PM
joshj52's Avatar
joshj52
joshj52 is offline
Did you ever figure this out mine has been doing this for the last week went to discount tire twice. I checked it my self last time the light came on all tires at 35psi.
Old 07-27-2015, 09:38 AM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
Is it intermittent or does it blink?
Old 08-12-2015, 03:43 PM
LeaseR's Avatar
LeaseR
LeaseR is offline
I think that over pressure will light it also. Plus you need to drive the car after adjusting the pressure to get the light to go off.
Old 08-13-2015, 10:01 AM
HemiLonestar
If it is lit solid, pressure is too high or too low. If it intermittently blinks, then there is an error with a TPMS sensor.
Old 08-13-2015, 11:46 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
What's your model year and type of engine, joshj52?
Quick Reply: Low tire light goes on and off
