Replacing thermostat on 2010 challenger
What was the exact code? A bad thermostat will not throw a code. A bad sensor could. Need to know the exact code before you just start throwing parts at it. It would also be helpful if you would state the year and engine of your vehicle. Thermostat locations differ depending on the engine.
Verify coolant strength & level
Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary. Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
If the above items check out good, replace the thermostat
