1999 dodge ram losing power
Old 12-08-2008, 07:01 PM
303artur's Avatar
303artur
303artur is offline
Default 1999 dodge ram losing power
Hi guys .
Please halp me with my problem .I own 1999 dodge ram 2500 diesel ,4x4 , auto . i have 110000 miles on the truck . Thkis morning i have start my truck like always no problem but afret few miles i just loose power to the engine I try to accelerate and no response to the gas pedal i have pull over . After 10 minutes i start the truck and it was fine for next 3 miles and then truck loose the power again . I replace fuel filter put new gas in and some injector cleaner but that did not help .No check engine light . looks like everything is the same no leaks or noises .Please help anyone I need this truck to work everyday .
Thank you for help .
Old 12-08-2008, 09:53 PM
garrettg84's Avatar
garrettg84
garrettg84 is offline
I've got a 99 4x4 auto as well. I have a similar problem, although i've isolated it to when i drive over 50 on the speedometer (not sure actual speed cause of tires) but its when I hit my 4th gear over drive.... after being in over drive, i accelerate like a SLOTH off the line. I feel like I have to put the pedal through the floor to make it move.
The next bit of weirdness will throw you for a loop. Try shifting your gear to first gear off the line. It will accelerate like normal, then pop it into 2nd gear, then to drive. When you take it manually into first, if its the same issue mine has, it will actually shift down. The truck's transmission has gone retarded and will not shift all they way back down to 1st gear after being in over drive. I took it to a friend of a friend's shop and he hooked it up to their computer and said that some 'governor pressure sensor plate' (or something to that effect) was too high. Can anybody confirm this?
The other thing that is similar, as soon as I turn the truck off and back on, she's good to run like normal again until I get over 50mph. I can actually shift into neutral and turn it off and back on while decelerating and get normal performance out of it again.
Old 12-08-2008, 11:41 PM
303artur's Avatar
303artur
303artur is offline
Looks like i have exacly same problem . At first It was at higher speed but later i have the issues even at lower speed .But same issue .
Old 12-09-2008, 12:41 AM
SpLaT's Avatar
SpLaT
SpLaT is offline
could be the APPS sensor (accelerator pedal position sensor)
Old 12-09-2008, 01:00 AM
SpLaT's Avatar
SpLaT
SpLaT is offline
You guys could try resetting the APPS sensor, try this:
- disconnect both batteries negative cables (let truck sit for 30mins with cables off)
- re-connect both neg cables
- turn key to "on" position -do not start
- depress accelerator pedal slowly all the way to the floor
- slowly let the pedal up
- turn the key to the "off" position
your APPS sensor should now be reset. Now you can start truck and take her for a run, see if this has cleared the problem. If not you may have to replace the sensor.
good luck!
Old 12-09-2008, 07:03 PM
303artur's Avatar
303artur
303artur is offline
I have try to reset the sensor and test drive the truck first trip was 10 miles everything ok but next trip same problem . I call dealer about the sensor but I was told 530 dollars for it . Can I get one somewhere for less . Thank you for help .
Old 12-09-2008, 11:22 PM
SpLaT's Avatar
SpLaT
SpLaT is offline
check rockauto.com or nearest cummins dealer.
rockauto has em for:
(throttle position sensor)
man tranny $333 - 497(mopar part)
auto tranny $337 - 471(mopar part)
Old 12-10-2008, 08:28 PM
scatpack_69's Avatar
scatpack_69
scatpack_69 is offline
Classic sign of your VP going out...that or the APPS.
My $$'s on the pump...
Old 12-12-2008, 12:27 AM
westwoodspeedster's Avatar
westwoodspeedster
westwoodspeedster is offline
sounds like my problem also
Last edited by westwoodspeedster; 12-12-2008 at 12:31 AM. Reason: wrong post sorry!
Old 12-13-2008, 06:35 PM
303artur's Avatar
303artur
303artur is offline
I have question if this was VP going out do I have the symptoms all the time ? It looks like that when I start the truck in the morning everything is ok but after some milage problems come back . Or if I disconnect the negatives for batt truck is ok also for some time . I just dont want to go to the dealer and pay big bucks but on the other hand if is VP , dont want to spend on APPS . Dont know whot to do . Any ideas guys . Thank you for your'e help so far .
Quick Reply: 1999 dodge ram losing power
