My 1999 24V (125k miles) is difficult to start when the engine is hot. When I first get in the truck in the mornings it fires right up, but after driving a bit if I turn it off and then try to start it, it just turns over fine but no starting. After cranking 10~20 seconds it does start. If I let the truck sit 4 hours or longer after driving it always starts right up. There are no codes. My VP44 is a little over a year old, as well as Edge Jammer injector tips. As for the lift pump replacement I'm running the FASS system. I'm showing plenty of fuel pressure (idle 15+ psi) before the VP44. Anyone have a idea as to what is causing my problem?
Thanks.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Have your batteries and starter tested.
If you don't have good cranking rpm you get hard or no starts.
__________________
97 Ram Sport ext 4x4, 5.9L gas, 3" pro comp lift w dual shocks, 3:55 trac lock
Lt305/70R16 Kumho KL-78, K&N FIPK, Mopar Performance wires and cap, Stainless shorty headers, Walker exhaust. All syn lubes. Sirius sat radio! Magellan GPS
2003 Grand Caravan Sport. 3.3L No toys in it. Nobody's cool in a Minivan...
My '01 is doing the same thing. I have noticed where the lines are going to the injectors some are leaking (leaking from inside or behind where it screws in) . I am thinking seals inside the injectors (IF there is any) after warming up they swell and allow fuel to leak?
Does this sound plausible?
Thats what I'm thinking. If it was the injectors themselves, it would do it all the time I think?
Its really pissing me off though.
FYI, I have replaced my IP and lift pump assembly less than a yr ago.
It DOES appear that leaking or broken fuel lines would be the obvious culprit but why only when its warm? Why not all the time?
In MY situation I DO see a little bit of fuel and its leaking from where the fuel lines go into the injectors (and they are TIGHT). Not pouring out but seems to be leaking. I don't see any leaks anywhere else from the tank all the way up to the filter, into the IP, etc.
It's possible for a leak between the lift pump and tank to suck in air and not have a fuel drip. Splice in a section of clear hose and look for bubbles or foam. bubbles = air leak
__________________
thanks
Hounds,
That sounds to me like the fuel line nut got overtightened and the compression fitting is shot.
The fitting between the HP fuel line and the connector tube is a compression fitting and, really, it's only suppossed to be used once. Can you get away with removing an installing it multiple times? Yes, but you need to ber very careful not to damage the head of the fuel line, otherwise a leak develops.
This can either leak fuel under pressure or it can allow air in when the system is off.
__________________
That thing gotta Hemi?...... I guess ya better bring two of 'em then!
