Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
3.9 - 5.9 swap
Old 12-25-2003, 06:11 PM
Black2k3.9's Avatar
Black2k3.9
Black2k3.9 is offline
Default 3.9 - 5.9 swap
I was wondering about how much the swap would cost and what else i would need to change besides the transmision. i have a 3.9 with 5 speed tranny.</P>
Old 12-26-2003, 01:55 PM
MonteC's Avatar
MonteC
MonteC is offline
what year are the engines?</P>
to start with, new engine mounts. theengine should bolt up to the 5sp tranny, and then just hook the computer up the right way.</P><edited><editID>MonteC</editID><editDate>37981.6737615741</editDate></edited>
Old 12-26-2003, 02:46 PM
dodgefreak's Avatar
dodgefreak
dodgefreak is offline
Well the 5.2 and the 5.9 are basicly the same motor....and the 3.9 IS a 5.2 with two less cylinders, so the mounts need to be changed but the tranny should be fine. You will need a new PCM, throttle cable, and wire harness...along with a handfull of odds and ends.
Old 12-27-2003, 09:16 PM
Black2k3.9's Avatar
Black2k3.9
Thanks yall, so how much would you think that this all would cost?</P>
</P>
Old 01-15-2004, 10:12 PM
backsdak's Avatar
backsdak
backsdak is offline
actually i was reading up on it on another dakota site and for the v8 swap because the 3.9L and the 5.2L engine are the same, you don't even need new mounts it all lines up, but thats just what i read, so sorry if i'm wrong
Old 01-18-2004, 01:00 PM
akaproph's Avatar
akaproph
akaproph is offline
How about you ask someone that has done the switch already... Go to one of the following sites, register and do a search before you just post how to do a 3.9 to 5.9 swap. The questions been asked alot and alot have done the conversion. Better know to know what you need than to waste money....</P>
www.dakotausa.com</P>
www.dodgetrucks.org</P>
www.dakotatrucks.com</P>
</P>
Have fun and enjoy your trucks!!!</P>
Old 05-05-2013, 07:50 PM
waynechoffman1's Avatar
waynechoffman1
waynechoffman1 is offline
Fan shroud must be replaced with corrected one for V-8 or shortened by two inches approximately. Computer should be changed. Wiring harness needs wires added for two extra cylinders. Everything else will work the same way.
Quick Reply: 3.9 - 5.9 swap
