Dodge Dart The Dodge Dart forum is the place for all Dart 2013+ Owners Discussion
Configuring a 32gb SDHC card
Old 05-04-2013, 08:36 PM
jwilson7256's Avatar
jwilson7256
jwilson7256 is offline
Default Configuring a 32gb SDHC card
Other then formating as fat32, is there a recommended way to configure a new 32gb SD card before transferring music to it to work with the SD card player in my new 2013 Dodge Dart Limited. I thought I heard somewhere that you should create several folders like Albums, Artists, Playlists, Genre or Music and separate the music to the proper folder so the player can access the card better when searching the card or do I just throw a few thousand songs in the root directory and use it that way? How did you handle your card?
Old 05-17-2013, 11:35 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
Personally I would just load it up and use the random option when playing so it will mix up the songs, that's how I do my old fashion cd's that I have MP3's on in my 08 Ram.
Old 02-03-2015, 11:31 AM
jimmyjam101's Avatar
jimmyjam101
jimmyjam101 is offline
Default format a new or used card
I had trouble when I formatted mine at first. I tried a smaller card that actually worked. After some investigation I discovered that my 32gb was formatted wroth 16k allocation units and my smaller one was using 32k allocation units. I re formatted the 32gb using 32k and it worked.
Quick Reply: Configuring a 32gb SDHC card
