upgrading stock speakers
The touch screen is not a radio, i is merely a touch screen input panel like a key boad. The Radio is at where you put the CD in.
as for how to remove the radio. You remove the this and radio is behind it
you pry off the 2 silver tab at #2 spot to expose the 2 screws, remove it, and pop the cover out by prying on #3,
as for the wirig diagram.
1 Z907 BK14 GROUND
2 X487 LG20 AUX AUDIO RIGHT SIGNAL
3 X486 LG20 AUX AUDIO LEFT SIGNAL
4 X488 LG20 AUX AUDIO COMMON
5 X489 LG20 AUX AUDIO DEVICE DETECT SIGNAL
6 D467 GY22 CAN(+) PRIVATE BUS FOR AUDIO TELEMATICS
7 D177 DB22 CAN IHS (+) - RADIO
8 X394 YL18 AMPLIFIED RIGHT REAR SPEAKER (-)
9 X304 DG18 AMPLIFIED RIGHT REAR SPEAKER (+)
10 X292 DG20 RIGHT FRONT SPEAKER (-)
11 X202 DG18 RIGHT FRONT SPEAKER (+)
12 A933 RD16 FUSED B(+)
13 X221 OR20 PASS TO RADIO AUDIO RT
14 X222 OR20 PASS TO RADIO AUDIO LT
15 X220 OR20 PASS TO RADIO AUDIO REFERENCE
17 D466 GY22 CAN(-) PRIVATE BUS FOR AUDIO TELEMATICS
18 D178 WT22 CAN IHS (-) - RADIO
19 X393 DG18 AMPLIFIED LEFT REAR SPEAKER (-)
20 X303 DG18 AMPLIFIED LEFT REAR SPEAKER (+)
21 X291 GY20 LEFT FRONT SPEAKER (-)
22 X201 GY18 LEFT FRONT SPEAKER (+)
1 Z907 BK14 GROUND
Crutchfield.com is a great resource for answering your question. Just go there nd put in your vehicle year/make/model, it wioll tell you what speaker size fits where. In the future, please start your own thread instead of posting a question in someone elses thread. Welcome to DF!
Same Issue
I am having the same thing with a 2013 Dodge Journey and the Rockford 3Sixty.3 processor using high level input. I was told the processor was bad but I am not convinced because it was brand new.
Trending Topics
Aftermarket head units? So is there a oem amp for the 4.3? I have looked all over the Web with no luck, I even looked at the wiring schematics on that Chrysler wiring site, I didn't see anything! But there doesn't seem to be a usable signal off the back of the radio! Found that out the hard way! Canbus related?
