DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon
Thread Tools Search this Thread
Old 06-15-2004, 07:55 PM
b_s_d b_s_d is offline
Default Torque converter clutch solenoid circuit problem (Code 37)
Does anybody have any ideas on how to track down a problem in the torque converter clutch solenoid circuit on a '96 Highline coupe? I clear the PCM and get a code 37 failure as soon as I start the engine - so appears to be some sort of hard fault.
However, the transmission seems to be operating fine and the Park/Neutral switch is working as it should. Seems almost crazy that the "check engine soon" light turned on by this particular code would keep me from passing the state vehicle inspection.
Would appreciate any suggestions or leads.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-17-2004, 11:33 PM
Default RE: Torque converter clutch solenoid circuit problem (Code 37)
Got an answer and fix on this. The torque converter clutch solenoid circuit connector is just behind the filler tube where it attaches to the a/t case. Found accumulated crud kept it from seating properly when it was reconnected after a prior owner's repairs - very lucky since replacing the solenoid is apparently not trivial. It must have been like that for a long time since it burned the "check engine soon" bulb out.
Reason this code turns on the emissions fault lamp appears to be that gas milage suffers a bit if the torque converter isn't able to lock at cruising speeds. Only other bad effect is extra heat in the transmission from the slippage that occurs whenever it is not locked.
Old 06-18-2004, 12:25 AM
NYG NYG is offline
Did you answer your own question?
__________________
'96 Nitro Yellow Green Dodge Neon DOHC SCCA SSC Race Car!
Old 06-18-2004, 01:12 PM
I try to post the solution/resolution for any questions I raise on forums like this regardless of where the help comes from. Figure it may make it easier for the next person searching the archives on a similar problem.
Old 06-18-2004, 02:07 PM
Dodgegirl19's Avatar
Dodgegirl19 Dodgegirl19 is offline
Lady Administrator
Dodge Forum Administrator
Vehicle: 94 Dodge Ram / 83 Dodge Aries / 02 Dodge Stratus R/T / 92 Plymouth Laser AWD / 72 Dodge Demon
So glad you got it figured out! And thanks for posting the solution!!
~Amanda
__________________
The Lady In Red
1994 MODIFIED Dodge Ram 1500 Sport
Are you LinkedIn? Let's Connect!
http://www.linkedin.com/in/amandarall
Old 11-04-2009, 11:21 AM
Dodge.Ismo's Avatar
Dodge.Ismo Dodge.Ismo is offline
Vehicle: 1995 Dodge Ram 1500 4x4
Default Code 37 !!!
Hello Dodge enthusiasts. Even thiugh this is an old thread, I also believe in helping others with important information. I had code 37 in my 1995 Dodge Ram Sport 1500-4x4 SLT Lariat yesterday, (Nov. 03/09). I found out some useful information that hopefully will ease some "Dodge minds" out there. 1) Everyone, I hope, knows about the code 37 definition: TCC, (torque convertor clutch solenoid [CKT]) or transmission temperature sensor too high or too low. *NOW*, if your "CHECK ENGINE LIGHT" is illuminated during operation, (while truck is running/ being driven), then this is your problem. *(behind Auto tranny oil filler tube, at its base, [where it "plugs" into transmission], the connector could be faulty, loose, or bad contact). *****NOW THE SECRET INFO!!!***** From the 1995 truck (Ram) manuals; Trucks with the trailer towing package, include a transmission coolant temperature SENSOR!.., with the "standard package" truck, it does not include this sensor. So... the fault code detection system is causing the low (no) voltage indication..... "NO SENSOR TO SEND ANY VOLTAGE" !! **So if you're getting code 37, BUT, the "check engine light",.. "DOES NOT" stay on during operation (while it's running or when you're driving it), this is your problem,... which means..there IS no problem. Hope this info helps, Dodge.Ismo.
__________________
DODGE.ISMO@hotmail.com "New project": Blk. 1995 Dodge Ram Sport 1500-4x4 SLT Laramie. 5.2L, Fully Loaded!
Tags
2000, 37, caravan, circuit, clutch, code, converter, dodge, durango, located, neon, ram, selenoid, solenoid, torque, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
